gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Tue Jun 30, 2009 2:11 pm
Yes it is possible.Remove the accessory belts and the crankshaft pulley. You can either use the correct tool, a seal puller, or you can use a small flat head screwdriver to fish it out.Wipe everything down well and make sure to seat the new seal as flush as possible. I have a piece of PVC pipe that is the right size to slide around the crank and gently tap the seal fully into place. Replace everything you removed after washing out the front cover with some Simple Green or Purple Power.
