Hello all,
I grabbed a door from a junk yard to replace my crunched door... driver side.
I wish to swap out the lock cylinder to avoid the need for a second key.
There is a rod attached to the cylinder that I have un-attached. I have also removed a retaining clip.
I think I'm close. Cannot pull it out from the outside as it is too bulky. Cannot pull in from the inside as there is a "cap" that is too large to fit through the hole.
