Replace Dashboard Lights
humuju
Car: 2009 Infiniti G37 S
At least one of my dashboard lights did go out. In the attached image, you can see that between the 5k rpm and 7k rpm indicator, the light did go out. Are there any instructions on how to disassemble the dashboard and replace the light? Also, what kind of light bulb is being used. I would like to purchase it before taking the dashboard apart. Also, what other lights are there. Since I am taking it apart, I might as well replace all lights with new ones.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Pretty much all Nissan/Infiniti clusters from around 2000 on have LED illumination, not bulbs. While it's possible to disassemble the cluster and solder new LED's to the mainboard, finding a correct LED for the application can be difficult. They're mostly 0805 surface mount and are too small to have identifiable part numbers.
