Replace Car Horn HELP
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
versa09guy
Hi guys, I want to replace my car horn, since all you versa guys out there know that they are the most embarrasing things out there! I would like to install some PIAA sports horns, but was wondering about the wiring. My 2009 versa has only 1 horn, so how would I go about installing the PIAA horns (there are 2 of them). Do i need to use any relays or mess with any of the fuses?
All help is appreciated, thanks a bunch!
steed77
Car: 09 Versa Fresh Powder Sedan 6speed
This JUST showed up today... I hope to have it installed in a week or so...when I have time.
http://www.amazon.com/Wolo-419...5DQWY
http://video.google.com/videos...num=4#
Shad0wXCalibur
Car: Nissan Versa SL Sedan
Maybe it's because I have an older model with two horns and possibly a different model of horn but while I find it higher pitched, I don't think it's weak or embarassing.
And if you only have one horn and want to install two, you may need a relay to make sure it doesn't burn up a fuse if you ever have to lay on it. When you're messing with a safety device, you wanna make sure you do it right...
NODES
Car: 2007 Nissan Versa SL (Blue)
Shad0wXCalibur wrote:Maybe it's because I have an older model with two horns and possibly a different model of horn but while I find it higher pitched, I don't think it's weak or embarassing.
I got 2 horns as well and it sounds alright for a small car, I honk people move over.
On a side note, my friend in his Blazer has a REAL life Train Horn When he honks people don't just move the fly off the road.
VersaMG08
Car: '10 Mazda 3 s hatchback
'14 Nissan 370z
This is the horn I have on my car. It's sounds better than the stock horn. Cheap and you can get at a local auto parts store.http://www.amazon.com/Wolo-310...uto_3
zgendron
Car: 02 Maxima SE 6spd - 09 Nissan Versa SL CVT
Shad0wXCalibur wrote:And if you only have one horn and want to install two, you may need a relay to make sure it doesn't burn up a fuse if you ever have to lay on it. When you're messing with a safety device, you wanna make sure you do it right...
Just an FYI. It appears as if the Horn Relay and the fuse (10A) are the same in 2007, and 2008+ models (1 horn vs 2 horns).
Horn Relay: http://www.courtesyparts.com/2...=6382&
Horn Wiring Diragrams http://www.nicoclub.com/FSM/ve...W.pdf (page 46)http://www.nicoclub.com/FSM/ve...W.pdf (page 38)
Therefore I'd guess you just need to wire them up in Parallel and you'd be all set.
Return to “Versa Technical Discussions”
