My Drivers side rear caliper is locking up and has been for a while. Also I did a full brake job on the car about 3 weeks and the front calipers are acting up. Im geeting a squeal up front which has become almost a grind. There is a thin line or a streak on the rotor used to be wat appeared to be gunk is now wearing out the rotor slightly. The rear caliper is getting dragging badly enuff to the point I can smell the rotor and feel the heat off of it.
Do you guys think I should just fix the reaccurring problems or do a 3zx brake swap all around to save on a headache and maybe a little time?
