Replace BOSE head unit with DOUBLE DIN receiver (pics) 02-04
mkmk
Car: 2004 Nissan Pathfinder Platinum Edition
EsotericImage wrote:Image
Looks great!
EDIT~ Ron.. did u have any extra wires? usually from what ive read is theres an Amp grounding wire that needs to be grounded for the amps to work.
Thanks.
I have few wires left.
Amp ground and Power anntenna on harness and Mute on unit.
Ron Burgundy
Car: 1999.5 Nissan Pathfinder 3.3 LE
EsotericImage: Yeah you're right... I forgot the amp wire (which is the whole point of this adapter!)
mkmk: You didn't have to ground the amp (black/white)?
mkmk
Ron Burgundy wrote:EsotericImage: Yeah you're right... I forgot the amp wire (which is the whole point of this adapter!)
No, I did not.
Do you use Metra or Scosche?
mkmk
FINALLY
Looks great, works well, sound better then Bose.
Next step - install blutooth adapter and connect steering wheel control.
KyooX4
Car: 2001 Infiniti QX4 4wd
Personally, I just replaced everything; head unit, speakers, amp.
mkmk
jacobp7201 wrote: What did you use for the trim surrounding the double din receiver? Is that a piece of ABS plastic or composite plastic you cut and modified yourself? Or is it from the standard single din Infiniti kit that you cut and modified yourself? Also, how did you mount/secure the trim?
It is plastic Kenwood Oversized Trim Ring for DDX and DNX Double Din that I purchased on eBay for $12. I cut it outsude to fit. Trim holds on unit only, not firm, but can't moved anyway.
jacobp7201
mkmk wrote:It is plastic Kenwood Oversized Trim Ring for DDX and DNX Double Din that I purchased on eBay for $12. I cut it outsude to fit. Trim holds on unit only, not firm, but can't moved anyway.
Ok, I see. I ended up making my own trim out of wood and wrapped it in vinyl.
GRNMACHINE
Car: 1999.5 Pathfinder SE 4x4
Thanks for the writeup and great pics and work mkmk-
funnyman82
Car: 2002 Infiniti QX4
Jacobp that setup looks sweet. What deck do u have there? What r all the wires and adapters u had to get?
2 Coupes
Car: Mine- 03 QX4
Hers- 07 FX35
funnyman82 wrote:Jacobp that setup looks sweet. What deck do u have there? What r all the wires and adapters u had to get?
It looks to be the pioneer avic f700bt. Nice unit good choice I almost got that one. I have the Pioneer Avic z110bt and love it.
I did mine about a year ago along with a viper security and remote starter. I feel like everyone is doing a tone of work to get their aftermarket headunits to work with the stock bose amp. All I got was a cheap adapter from amazon or ebay and matched the colors from the headunit and the adapters and poof it all worked. The trim piece was a pain though. I used a clear piece of plexiglass and cut to size and painted it with duplicolor black primer and it matches perfectly. I will take pictures and post a little bit later. Let me know if anyone has questions on doing the steering wheel control adapter it is a great feature to have the steering wheel controls with the aftermarket stereo. I recomend the PAC SWI-PS found here http://www.pac-audio.com/swixprogrammin ... amming.asp
devonianwalk
Car: 99.5 Pathfinder LE 3.3
EsotericImage wrote:I just bought an 02 and the "all highs/no lows-must be Bose" stereo sucks. too muddy. Now ive heard good and bad on the signal processors. Which way do i go?
Close ... It's actually "No highs, just lows .. must be Bose". Pay close attention to Bose products. They NEVER list their frequency range as they do not want you to know that they "clip" the signal at the high end. This is what the sales peeps call "voice matching". However, they do sound better than built in tv speakers! :naughty:
jacobp7201
I have the Avic-710BT installed. I just bought the typical Nissan/Infiniti harness and the antenna adapter. I didn't re-use any of the Bose stuff...I had to wire through every door directly to my amp. I'm currently running 6.5 Reference series MB Quart components in each door.
iceman14n
mkmk wrote:Took this one
and after cutting, cutting and cutting...
Hey man, can you please tell me where you got this Square trim from? i really need something like it.
ANd how did you mount your doubledin Kenwood in there? did you just use the original mounting or did you modify a single din mount?
thanx
jostell13
Car: 1994 J30
2003 Pathfinder LE
Hey old thread I know, but was hoping to get a quick question answered. @mkmk, do you know what this port on the back of the OEM unit is:
http://imgur.com/lW4Lx
I had an adapter made for the HU in my '94 j30 that uses this same 8-pin connector and had hoped it would work the same on my 2003 Pathfinder's OEM HU, but after plugging it in i'm getting no results.
Any tips appreciated thanks
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
I believe that is for the auxiliary connection used by the rear TV option, if so equipped.
jostell13
Car: 1994 J30
2003 Pathfinder LE
I have no rear TV equipped, but there was already something plugged into it. If this is for the rear TV wouldn't it support line-in sound? Perhaps the pin configuration is different than in the j30, thus my adapter won't work.
Towncivilian
I'm probably misinterpreting the wiring diagram. Perhaps it is for one of the antennas. You can find a wiring schematic and diagram on page EL-194 of the factory service manual.
