Replace aluminum console storage lid latch
Forum for the unique Murano, and official home of Nissan Murano Club!
Penny's Dad
Car: Murano '06
I recently purchased a new aluminum trimmed console lid latch assembly for about $22.00 from Nissan. The old one was pretty beat up and I was going to cover with a trim kit but discovered a new one was cheap...
My problem is that replacing seems to be pretty tricky and appears to be a multi-step process.
Does anyone have suggestions about how to go about it?
Thanks in advance.
Penny's Dad
Car: Murano '06
Thanks,
You guy's were a huge help...
So I got with my ex fighter pilot Dad this weekend and we figured it out...here are the steps in case anyone else wants to try this...the new trim cap looks great btw.
1. Open main console lid and lift assembly to upright.2. pop off trim at base of hinge assembly to reveal lid attachment.3. remove lid attachment (8 screws) Have someone hold the lid while you remove last screw.4. remove entire console lid assembly (you will need to close the lid and it will slip out)5. remove 4 screws holding the bottom cover on.6. remove the 8 screws holding the sliding bracket on7. you can now remove the top of the lid assembly and get to the upper compartment lid release mechanism8. remove this mechanism and you can now pop out the aluminum trim cap (you will need to rotate it a bit to make it come loose).9. replace with new trim cap and reverse all steps.
Fin.
I understand why this part takes so much abuse since it is the exact spot where the seatbelt trim edge hits if you are not careful...Anyway for $27.00 and an hour of time mine is now fresh and pretty.
Hope this helps the next guy!
Macsleuth
Car: 09 Nissan Murano SL
Thanks for posting the steps.
DG65
Car: 2006 Murano S AWD
I need to do the very same tging but was afraid I'd have to mortgage the house for the new trim!
$22.00? That's good news.
1991_240SX
Car: 1991 240SX
2006 Pathfinder LE
2006 Murano SL
There is a much easier way to replace the: Upper Lid Aluminum Trim Panel Latch Assembly. This can be performed by simply removing two screws. The removal and installation is covered in detail(5 PAGES) in Nissan's SERVICE BULLETIN Reference: NTB07-085 Classification: BT07-040 Date: November 16, 2007. Titled: 2006-2007 MURANO; CONSOLE BOX UPPER LID LATCH AND ALUMINUM TRIM PANEL
http://x.nissanhelp.com/forums/Knowledg ... 87&id=1963 (knowledge-base keyword filter: console)
Description: Latch Assy - Console Lid (console box upper lid and sliding arm rest latch assembly)
The part number to order for a replacement: 96927-CC20A
Total Cost with shipping from Courtesy is $30.81
Return to “Murano Forum”
