replace a VAC line with fuel line ??
nissan_star
Car: 2000 maxima se and 1993 240sx vert (5sp!!!)
All they had at the store that fit was a fuel line, which is much softer then the VAC line I removed. I always figured it was stiff because it was old... and thats why it cracked.
Would this fuel line cause my brakes to feel softer because of the vacuum pressure deforming the line?
Lonismos14
Car: 1995 Nissan 240sx, 1999 Chevy Hoe, 1996 Saturn Sl2
actually a fuel line is stronger than a vaccuum line u should be fine.
nissan_star
I know it holds more psi or whatever, but i can squish the fuel line between my fingers, I can't squish my old vacuum line at all. So under vacuum will i be pinching the fuel line shut a little bit? The fuel line is designed to be under pressure from the inside pushing out, in its use now, it will be under pressure from the outside pushing in, like when i pinch it.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Lonismos14 wrote:actually a fuel line is stronger than a vaccuum line u should be fine.
This is not correct. The burst PSI on fuel line is more, but the crush rating on vacuum line is greater. Depends on what line and where it is. I have used fuel line as vacuum line with no issue. When I ran my booster off my intake I used heater core hose, no issue.
Lonismos14
uh sir you are not correct, cause im running fuel line off my break booster.An goodyear fuel line can actually hold more vaccuum than a vaccuum line thats why alot of people including me rebuild there motors with fuel line.
thanx though
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Please look up the rating on lines before you make assumptions.
Vacuum line is rated in by crush strength, the walls are thicker and the rubber is designed not to collapse. Rating for vacuum line are rated in vacuum feet per inch as well an tensile strength at determined bends.
Standard fuel line, is rated in burst PSI as well and constant PSI as well and tensile bend VS constant operating PSI
So bottom line there genius is yes it may work, but there is a reason there are lines rated for vacuum, fuel, EFI fuel, oil, hot water, and ethanol applications for cars.
safin
lucky havent got any problems yet learn something new everyday
