daneo »
https://forums.nicoclub.com/daneo-u157904.html
Wed May 18, 2011 9:03 pm
Hi everyone. I've been reading these posts for a long time, so thanks for all the help! But, now I come seeking advice.
I have inherited a low mileage (30k) 1990 300zx 2+2. Clearly, it has spent a lot of time in the garage, and thus has had its share of old gas sitting in it. When I first fired it up, I let it idle a while. Some light white smoke came out the exhaust. I think this was due to the ancient gas it had in the tank and lines. The idle was rough and had a miss. After getting new gas the car ran well and the miss worked itself out. Then, I had to leave the country for 9 months and the car sat again. A tiny bit of white smoke came out the first time it was started again, and the miss was back. I've been putting seafoam in every other tank of gas to try to dissolve gunk and absorb water from old fuel. The miss seemed to fade in and out. For certain, there was a week where everything was running smooth. This week, however, the miss was really bad and the power loss was extreme.
Today I started doing some investigation. By pulling plugs from ignition coils, I found that cylinder 2 was the culprit. I did the ol' big-screwdriver-on-the-injector-body trick to listen for clicking. The injector was clicking, but not as loud as the others. I popped off the injector harness and checked the injector resistance. it was 782 ohms rather than the 10-14 spec... So, it seems that my injector has probably been slowly dying.
Now, like the title of the thread indicates, I'm trying to decide with replacing the P1 pintle-style injector via the dremel method (90 bucks and a few hours) OR pull the plenum and replace all six with P2 injectors using the Deatschwerks kit (700 bucks and all weekend).
What are your experiences with injection failures? Everything I've read shows people swapping out the 6 once the first is dead. This is under the pretense that "the others aren't far behind."
Thanks for the input.
