Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Fri Apr 15, 2005 5:56 pm
I read in another post that it was 4 teeth counterclockwise, which would be retarded 18.9', but you should be able to use the direction of rotation and then find a place where the cams are at rest on #1 and the distributor gear was placed at 16'BTC (I believe is base timing on the KA), then with the bottom end loose, set it at TDC. Then you would mark where the intake side is in relation to the marked chain, then have it installed there. Of course, I could just be blowing smoke up your arse, so find a second opinion.
