Kidastra wrote:Hey, I work at a Nissan dealership, this is my first post. As far as the links on a scale from 1-10 I'd give it a 3, the only problem you may encounter is if they were changed before and jobber parts were used. Then you will need to grab the shaft with vicegrips while removing the bolt, it is literally a 10 minute job.
Kidastra wrote:Oh and I suggest using original Nissan links, the jobber ones don't seem to last as long
Adnan wrote:About the transmission fluids, the mechanic recommended not to change the fluid in my mom's 96 Windstar since it could lead to future transmission problems...haven't touched it and still runs strong.
Agree with all three comments. My link bolts were a bugger to crack loose.All that salt we get in winter didn't help. I had to use vicegrips like Kidastra said.Still, it's not that hard. Definitely a DIY job.Also agree with you about using Nissan parts. They're not that expensive.Lastly, I had a 1996 Windstar (which I hated), and did a transmission flush a few years after I got it. Nothing but downhill after that. I traded it in on my Pathfinder mostly because it needed a new transmission. I couldn't wait to get rid of it.All in all, I still have to give it some thought whether to go ahead and do it on my truck.
