Hello all -
I have purchased some Window Weld to reattach the convertible top window to the canvas. I came across a number of sites on the web in searching for the stuff where folks are using it to repair worn engine mounts, etc.
So my questions is - has anyone ever tried to use the stuff to repair a worn control arm (In lieu of replacing it). The material is a single stage urethane that dries into a rubber-type material, about the same sitffness as stock busings and mounts.
Thoughts? It wont take much of the tube to fix the window, so I thought about using the rest to see if I could restore my control arm bushings.
-scott
