Repair Rear Seat Panel
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
My rear seat panel came loose a while back. Turns out the two clips on the top broke off and the plastic around the holes on the bottom shattered. I super glued this puzzle back together, but it didn't hold. Any ideas other than waiting on a black Q to hit the local JY?
AlabamaDan
1998 Infiniti QX4
No ideas from anyone? Anyone got a black seat back from 94-96 laying around?
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
Off of http://www.car-part.com:
1994Seat, RearInfiniti Q45 BLACK,BUCKET,LEATHER A 7L0010 $150 Macomb Auto Salvage, Inc. USA-MI(Warren) Request_Quote 1-800-837-7735 Request_Insurance_Quote
1994Seat, RearInfiniti Q45 4DR,4/94,BLK,LEA A 060514 $50 Action Auto Parts USA-IA(Marshalltown) Request_Quote 1-800-373-3995 Request_Insurance_Quote
1994Seat, RearInfiniti Q45 -LTHR BLACK WALK IN 1460 $49 Super Auto Dismantler USA-CA(Stockton) E-mail 1-888-358-0333
Q451990
As far as I remember the seat back has metal tabs that fit down into plastic receivers in the car's body... could be wrong though. Are you sure the plastic parts aren't actually retainers that could be ordered separately?
Heath
Denver90Q
Car: 1990 Q45 145K miles beige, 1995 Q45t green 80K miles , 1998 Frontier 140K miles black
There was a nice black seat at the local Upick and Pull. I got some parts off it during their two for one special last week. The seat bottom was lying in the mud but the top was still in the car.
AlabamaDan
1998 Infiniti QX4
It's not the back seat. It's the back panel of the front seat. The one with the pocket.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
had similar instance on my silver '94. i used plastic (PVC) glue and a fender washer (on the inside) to hold all the broken bits down. put it in a press to set up. may need a longer screw depending on washer thickness.
AlabamaDan
1998 Infiniti QX4
Super Glue didn't hold, but maybe the PVC glue would. You're talking about the stuff plumbers use?
SanCarlosQ45
Car: 1994 Q45 144,000
2013 Nissan Xterra Pro-4x
1967 MGB GT Special
A good amount of JB Weld Epoxy should do the trick. I am not familiar with the design of the part, but if necessary you can include supports within the epoxy like pieces of wire etc. I just repaired a carpet cleaner attachment with JB weld and it has held up perfectly; repaired a higher pressure water supply hose plastic piece that is probably twenty years old.
Just remember to sand the parts to be glued down and clean them well with something like denatured alcohol. You can use the quick JB weld which can set within 30-40 minutes, but need to cure overnight.
Q451990
Are you talking about the clips at the top of the seat back, or the tabs with the screw holes at the bottom? (I'm making an assumption that the design is similar to the 90-93 style)
Heath
AlabamaDan
1998 Infiniti QX4
Q451990 wrote:Are you talking about the clips at the top of the seat back, or the tabs with the screw holes at the bottom? (I'm making an assumption that the design is similar to the 90-93 style)
Heath
Both top and bottom.
I didn't know JB Weld worked on plastic. I thought it was for metal. I like the idea of reinforcing the repair.
Q451990
The 90 Q has screw holes on the bottom that can break out... especially if someone is rough with the seat back or props their feet on it. On my old Q I clamped a piece of aluminum flashing over this area and drilled holes for the screws. The area was too damaged to just use a couple of flat washers, and it's hidden from view anyway. I don't have anything good for you on the top...
Heath
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Remember they're talking about JB weld epoxy, which I believe is different than regular JB weld...
I would assume theres maybe a little bit of the tab remaining... Could you maybe put a screw in it going vertically so that it clips on the inside of the back of the seat...? Or some sort of hook, id have to think youd have a little bit of plastic there you could drill in. I dont think epoxy is going to work, but maybe, ive never used it.
Its hard to make something do what its supposed to do and not look tacky.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
AlabamaDan wrote:Super Glue didn't hold, but maybe the PVC glue would. You're talking about the stuff plumbers use?
yes. the reinforcement is important too. Heath's idea is similar---i just happened to have some fender washers (small hole, big O.D.)
Drake57
Car: 1992 Q45, 1990 Q45 (parts), 06 Sportster XLC, 85 XJ6, 08 4Runner, 89 Suburban 4WD, 75 Honda CT90
Epoxy formulated for plastic repair is readily available, and cheap - $3 at walmart. Last night I used some to glue my padded dash down which was shrinking and bowing up near the defrost cowl - tonight I will unclamp it and see if it holds.
I have a similar problem to AbD's with the bezel on the passenger door that holds the window and seat adjustment switches - the molded retainer features that should snap in to place are snapping off. I did scab a tiny piece of metal over the broken plastic finger, similarly to how one may scab a 2x4, and it did hold until I had to remove it again. In this case I'd used JB weld, instead of plastic repair epoxy. I think I will use a counter sunk screw and fasten a metal extension to the bezel.
Plastic is an inexpensive, wonderful material, except after it ages, turns brittle and snaps.
NASCARLANCE
Car: 2011 Juke SL AWD
1995 j30t
1988 Hardbody
I bought some stuff at Advanced that worked better on plastic than anything that I have ever used before. It's called "Plastix" by Loctite. It's a 2 part adhesive, like you would use on PVC pipe, with a cleaner/activator and a glue/bonder. Like on PVC, the activator seems to soften the edge of the plastic for the bond to be a real chemical reaction fusing the two pieces together. http://www.hardwareandtools.com/invt/6784466 There is also an epoxy with a similar name, so be careful, I don't know how well it works.What part of Al. are you in? The Pull-a-Part in B'ham has gotten 3 Qs in the past month or so. I think it was 2 94s and 1 92. You can go online and check to see what cars they have in. Whenever I have went there and just got small clips and stuff they will just give it to you.On a different subject, do you still have the black J30 floormats that at one time you said you were thinking about selling?
AlabamaDan
1998 Infiniti QX4
Mayb
NASCARLANCE wrote:On a different subject, do you still have the black J30 floormats that at one time you said you were thinking about selling?
Maybe...somewhere in that mess of junk in my basement. I only had them like a week or two before my wreck. They're in perfect condition.
NASCARLANCE
1995 j30t
1988 Hardbody
I'm looking for a set, but I'm not in a big hurry. If you run across them send me an email and I will meet you somewhere and pay you for them. I live toward Walker county, about a mile from the world famous Wesley's Boobie Trap.How is your seat repair coming along?
