Then it's a piece of cake, cut, splice if needed with the correct gauge wire, then run all 3 into a new universal battery terminal.Blindaviator wrote: ↑Mon Sep 04, 2017 11:06 pm
Red part is a connector. You can unplug both acc wires from it.
The only problem with getting an OEM part is that main battery wire is so deep down in the wiring looms it is nearly impossible to get out. I worked on trying to remove it when I had the engine out and gave up electing to add on the one pictured and simply tuck the old one off to the side. I didn't have any cutters large enough to cut the old wire off at the loom to get it out of the way. I did something similar with the ground wire.
nissanclub2001 wrote: ↑Fri Sep 08, 2017 11:01 pmAppreciate the response!
Any links on the parts that I would need of that you used, looks great and reliable![]()
Do you will think that will fix my issues or would it be something else based upon my pathfinder symptoms?
amc49 wrote: ↑Sat Sep 09, 2017 2:14 amThe vehicle battery itself needs to be loadtested for proper CCA, it could be an issue here too.
I have seen issues with marine connectors like that picced there, the aftermarket battery cable may well have a pretty loose hole fit on the post and the small footprint wing nut adds to it by neither side of the cable getting good big footprint contact. The handtightened wingnut makes it worse when the cable moves to not be tight enough to carry full power. A regular wrench tightened nut is better for power carrying with a bigger OD washer under it to contact more of the cable flat and the entire connection if left dry like that then causes more trouble with time as it corrodes. I myself messy as it can look use grease in between all surfaces to block oxidation and then it lasts whoppingly longer.
As well, the white cables shown in pic are fine but look between the crimp and the terminal and how thin the rest of the cross section is on the crimp fitting where it's dead flat, no way is that fitting going to carry as much power as the much bigger cable will.
