C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Fri Sep 29, 2006 11:17 am
Replacing the quarter panel involves cutting it out and welding a new one into place. Most cars, a 1/4 panel replacement requires 18+ hours for the 1/4 panel replacement alone. Does not include paint. And as far as painting, replacement requires repainting the entire panel and the jambs, and blending into the door and the trunklid. In your case, if the door is replaced, the blnd would go into the fender. The blend would only paint color onto a portion of each panel that blend is done on, but the entire panel would require new clear coat.
To repair the panel, they would blend the paint within the panel and only need to apply clearcoat to that panel alone. Normally the door would need blend time as well with the damage being so close to the door, but since your door needs repair, or replacement, then they would be painting that part either way (as a full paint if replaiced or blend if repaired).
In short, it's not going to matter if it's repaired or replaced as far as the paint is concerned. This is where choosing a shop with state of the art equipment and great quality control matters.
