Repair Driveshaft Propeller Shaft
digorf
Car: 2014 Nissan Rogue SL AWD
My driveshaft (Propeller Shaft) 08 nissan rogue SL AWD is bad, and makes the car vibrate in low speed, and nissan wants $1103.00 to replace the hole unit. Can I replace just the Universal joint that is bad, and save a buck or two? Or is unserviceable and have to be the entire unit?
And If I want to fix it myself, which U-Joint to buy?
darylzero
You could buy it yourself and have them install it. http://www.courtesyparts.com/-c-7712_77 ... _7845.html
$1103 doesn't sound too bad. Call other dealers and see what they would charge, if you find a lower price as your dealer to match it.
Other you could buy the parts yourself, make sure those are the correct ones, and have another mechanic do it for less.
Return to “Rogue Forum”
