Repainted my valve cover
score
Came out pretty schweet.
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
writeupp!
u think u could do a step by step on how to make it look so good? i'm interested in doing something similar...maybe
score
MainEvent212 wrote:writeupp!
OK, here it is:
Step one: Remove valve cover.
Step two: Drive to body shop
Step three: Ask them for a estimate.
It dosnt look that hard. Tape off all the important stuff, paint, then sand the lettering to get rid of the paint.
silkk
Car: 94 B13
89 S13
07 S2000
that looks hot
mynismo
sex in a cover. that is hott.
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
yea, that looks really good
Hijacker
Car: '92 240sx Convertible
'94 F-150
did they paint the lettering or did they just brush it back down to the aluminum after they finished painting everything.
Another thing I meant to ask last night on AIM, what paint code did they use to match the paint?
score
tenkawa_akito wrote:did they paint the lettering or did they just brush it back down to the aluminum after they finished painting everything.
Painted the lettering than sanded the paint off.
As for the code I have no idea. They said it was a factory Nissan color, but thats all.
mynismo
how much was it may i ask? you can buy brand new valve covers from phase2 for $175.
getnrowdy23
Car: '95 sr20det 240sx se/2004 suzuki sv650s
thats pretty
timmybgood
Car: cars
that looks really nice
i got a question though, that T on the side of the valve cover in the first picture, where does the tube on the left side go? i'm in the middle of installing my SR and i'm not sure where to connect it.
Hijacker
'94 F-150
mynismo wrote:how much was it may i ask? you can buy brand new valve covers from phase2 for $175.
any good paint shop can do it cheaper than what the new one costs. JGY customs powder coats them for $80
score
Powdercoating is probably a better alternative than paint. You may lose the 'bling,' but its worth the durability.
Nismo_Freak
Car: 89 Nissan 240SX
My OEM valve cover
SpeeDDrifT
Car: drive. drift. drive....um drift...SAFELY. k
wow nismo.......very nice...
chickentendah
Car: SR20DET Hatch
nobody here is into polished valve covers or wat?
nice repaint job btw, it's very
MainEvent212
nismo u copied me!
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
score wrote:Powdercoating is probably a better alternative than paint. You may lose the 'bling,' but its worth the durability.
Why do you lose the 'bling'??? Powdercoating is very versatile when it comes to the colors and effects that it can produce.
I had mine powdercoated with a two coat color that matches my Mediterranean Blue factory paint. It has a base coat and a metallic top coat. It's as shiny as paint and I've spilled fuel all over it and you can't tell at all.
others:http://www.streetelite.net/pics/bluebay ... rstday.jpg
Modified by cnichols at 11:47 AM 9/26/2004
score
cnichols wrote:Why do you lose the 'bling'??? Powdercoating is very versatile when it comes to the colors and effects that it can produce.
I had mine powdercoated with a two coat color that matches my Mediterranean Blue factory paint. It has a base coat and a metallic top coat. It's shiny as paint and I've spilt fuel all over it and you can't tell at all.
I stand corrected. That looks very "blingy" indeed.
2Fass240us
Car: 93 240SX SE w/redtop
score wrote:That looks very "blingy" indeed.
How bout mine?
Beadblasted, powdercoated CAT yellow, and letters sanded off with 320-grit. I plan to hit them with some ~600, mask off the cover, and clear the letters to ensure they don't get dirty (since bare Al tends to show dirt very easily).
The best part? My powdercoating was free through an industrial hookup! Too bad I no longer have access to it.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Looks great man, I need to do this myself...
Nicksemianiw
Car: JDM 89 Silvia K's
I might do myne white with a CF spark plug cover and either red or black lettering
cheez80
Car: percussion =D
when i get z32 brake caliper f/r, those will be powdercoated pink. i'll be powdercoating my valve cover to match =D
2s4x0
Car: 1998 240sx
Also, what i did, is sand the valve cover, then put vasoline on the letters.3 coats primer3 coats flat blackThen just get a paper towel and whipe the letters and the vasoline comes right off so there is the silver letters, then:5 coats high gloss.
2Fass240us
Nicksemianiw wrote:I might do myne white with a CF spark plug cover and either red or black lettering
This combo would look best with black lettering IMO. I thought about black, but decided it wouldn't look right with the yellow. I think sanded (aluminum color) letters look best for most valvecover colors.
