Don't worry abourt the CV's...its only for front wheel drive.Smartidiot wrote:My apology for asking this question.. but what does "CV" in CV joint stand for?
..can you please tell me what woudl the implication be if i don't replace the defective part???.. am i putting myself in danger on the road??
and no. iam not the 1st owner of my car.. tahts why i am kind of concerned here..
any advice is greately appreciated
thanks for the tips.. so if the tierod that you were referring to in your post is equivalent to the "strut rod" listed on Riverside Infitini online shopping site.. then to replace it would cost me over US$175 jsut for the part??!?tollboothwilley wrote:My guess (tierod) is because I have never heard of bushings going out. You can call your dealer parts/service counter and ask them. Bushings will normally wear out but not a for a while. Rubber needs time to crack and break. Plus, a bushing would likely be heard more than just when turning.
If bushings go bad, it will just sounds really bad and put a little extra strain on the suspension.
If the tierod goes out completely you wont be able to drive.
Call the dealer and i bet they'll guess tierod.
I know my lower control arm bushings are shot. Need to replace bushing and not the entire arm/bushing assembly. Any services in AZ for this? Dealer says can only replace bushings with hardware. I don't think so.tollboothwilley wrote:My guess (tierod) is because I have never heard of bushings going out. You can call your dealer parts/service counter and ask them. Bushings will normally wear out but not a for a while. Rubber needs time to crack and break. Plus, a bushing would likely be heard more than just when turning.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
