RENTING: Socket for ARP head stud installation
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
Well I came into the problem with finding a 12pt 13mm (1/2") socket for installing the ARP head stud bolts. The Craftsman ones I have just dont fit into the head to get down to the bolts. But I finally got a socket and will rent it out to anyone who needs it FOR FREE (CA owners like free).
Just shoot me an e-mail or reply here and I'll mail it to you, but you have to mail it back when you're done!
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Yeah man that's something I had my head clearanced for. I was seething with rage when I went to take the head off and a) my awesome medium-wall ARP specific slim 1/2in socket was MIA, and b) my craftsman deep wall 1/2in socket was mockingly close to fitting. Spitting in my face even. Went to machine shop and said "want fit here!! RAWR!" and pointed. Totally worth the $40 or whatever because now I just laugh maniacally when I get to that point in assembly/disassembly.
sjbsuperman1425
CA18DET
i was dragging my knuckles around like a caveman when my craftsman socket wouldn't fit. but i sucked it up, and found a el-cheapo socket over at my local hardware store for $3 that will work just fine
float_6969
Yea, my CA ARP head stud socket is a cheapy 12pt that I ground the outside off of till it cleared w/o touching.
r34 gtr
Damn... ..mine was like $15. It was soooo boss though!! Believe me when I say it was boss.
I agree sjb, not being able to remove engine bits turns me into a knuckle-dragging caveman too. I grunt and throw things in a blind rage.
I don't know if anyone is going to need to rent this, but its really cool that the offer is out there. Cheers!
sjbsuperman1425
CA18DET
i doubt anyone will need to rent this either, but if someone would've offered this to me, I would've jumped alllll over it haha.
float_6969
Like Tim on a cupcake?
r34 gtr
Dude I frickin love cupcakes...
sjbsuperman1425
CA18DET
its a good thing nobody picks on me like they do you Tim..
but unlike you..i am just.
float_6969
r34 gtr wrote:Dude I frickin love cupcakes...
He also loves beer. Beer and cupcakes.
magmonster
Car: 67-PL410 (bluebird) / CA18DE-T
Did your head stud kit come with washers too?Mine has washers and there is no way they will fit into the existing head bores (or cavities) Should I put the washers in the head first, and then try to set the head on the studs? and then try to find the correct 12pt deep socket?
sjbsuperman1425
CA18DET
yea put the washers in the head before putting the head down. works way better. then dry the socket. I had to buy a craftsman thin wall 13mm 12pt deep socket and still grind it down. works like a charm tho
magmonster
Ugh, ok. I was hoping to find something that I could buy off the intarwab to get this done.
I just figured out the washer thing as I was typing the first message.. doh!
did you just grind the tool with a bench grinder or lathe it down?
sjbsuperman1425
CA18DET
basement bench grind and a couple eyeballs FTW.
magmonster
Awh, this should be fun...I hate bench grinders...(my fingers hate them actually)But I guess, I could put an extension on it eh?Now I'm thinkin... hahahaha
KEMP
Car: 1990 240sx CA18DET
or a snap-on 13mm 3/8" with an adapter, works with out modifying.
magmonster
Just turned one down on a 12pt deep socket on a lathe today. No problems now.
burnt_rice
Car: sil80 built
any chance for a photo of what your socket looks like? mine are allll too thick. my 13mm certainly doesnt fit, and its relatively narrow.
sjbsuperman1425
CA18DET
i bought a craftsman 13mm thin wall socket from Sears and then had to grind it down to make it fit.
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
I was concerned wit the tolerance that the flanks of the socket made contact with the flanks on the nut so i ordered a snap-on 13mm 12pt (snap-on 12pt sockets are tolereance to + or - .0005 or .001 total) and then turned it down .020 on the lathe in the machineshop where im in college at
float_6969
I've still got my ground down socket, but I think the next time I have the head off I'm gonna have the bores opened up as there are a couple that still rub a little and I don't think there is enough meat left on the socket to take anymore off of it.
s13drifter88
u can actually grind one down almost paper thin and then take a cheap torch with a tank of mapp gas and heat it till its red hot for 60 seconds and then drop it down in water to harden it. do it only once but anymore the rockwell scale gets to high and the steel will go from hard to brittle
blownhemi
Car: S13 200SX CA18DET HX35
Can anyone confirm, if the 1/2" socket fits over it perfectly, like it should? I've seen both 13mm and 1/2" being mentioned. Thanks!
sjbsuperman1425
CA18DET
I just bought a house Dec. 16th 2013, and have yet to move all my tools to my new garage (lots of snow and sub-zero temperatures..), but its warming up to like 30 today and tomorrow so I'm going to grab my tools and take them home. I'll dig the socket out and take a look at it. I'm pretty sure I used a 1/2" to 3/8" adapter and used a 13mm socket that I took to the grinder. I'll throw a pic up here tomorrow as well.
float_6969
I'm 100% sure mine is a deep well, 13mm, 12pt. socket that I ground down to fit.
blownhemi
Thanks, I know a 13mm socket works, that's what I used last time, but I had the head clearanced for it. I'd rather not do that again with another head, should it come to it, but grind down a socket instead. I'd just like to make sure what the right socket is. 13mm vs. 1/2", that's +0.3mm more material I can leave on it, which is a lot for a thin wall socket.
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
On my SR's head studs, I used a 12point 1/2" socket, but it's 3/8" drive on an adapter.
blownhemi
Went straight to the source to confirm, since I'm hearing multiple reliable sources telling different things.
ARP, (Automotive Racing Products) wrote: 202-4702 and 202-4302 both have 1/2 socket head.
For reference, one is the Euro, the other the JDM head stud kit.
I'd say, avoid using the metric 13mm socket, if you have the chance.
