removing traction control on 94qt
jose310
Car: 1994 infiniti q45t
is it possible to take of the traction control on 1994 qt, like a switch or something under the hood???
Q45tech
What's wrong with turning it off with the inside switch everytime you start car that way you still have it in winter?
jose310
were is the switch located??
goody90q45
Car: 1992 Infiniti Q45 (sold)
The TCS on/off switch is located in the center console, between the heated seat switches.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
jose310 wrote:were is the switch located??
RTFOM.
It is free to download if you don't have one.
jose310
i dont any switch between the heated seats its just a small square hole...the "t" in Q45t stants for touring or traction?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
It should be right next to the seat heater switch. If not, you do not have traction control.
t is for touring.
apossiblehybrid
Car: 1994 Q45
why do you want to remove the traction control? is this going to be a drift car?
Q45tech
It dawned on me that you could use a relay driven from WOT switch or TPS voltage to turn TCS off whenever you floor accelerator..............in a emergency when you pull out infront of a semi.
