TheOne™ wrote:it'll help the engine get to optimun temp faster, but some people have taken it out and have had no problems at all.
Other way around...takes MUCH LONGER to get to operating temp.
The thermostat stays closed until it reaches temp, then pops open to cool things off...then closes when it gets too cool, then opens when it gets hot...etc, etc...
Usually removing it HURTS cooling b/c the water moves through the radiator too fast...coolant needs a certain amount of time in the radiator to be able to shed the heat it's picked up from the motor
If you must remove it, gut the housing (remove the center part - the plunger), but leave the outside so the opening is no bigger, that way the flow will stay at the right speed, and allow the radiator to do it's job.
TheOne™ wrote:i say if your car is not having any problems just keep it in there.
^^^ That's the best advice.
- Brian
