how do you have to mess with that thing to take the plenum off?ScottJackson wrote:Watch out for the VVT hydrostatic rod! It's under high tension and the spring will shoot it straight through your head as you're bending over and lifting up the intake! It won't kill you, but will likey disfigure your face/skull and adversely affect your psychological well-being (like Phineas Gage)... J/K :p
Care to highlight that in the picture? I would like to know where this potential killer lurks.ScottJackson wrote:Watch out for the VVT hydrostatic rod!
This post brought to you by WACKY TOBACKY...ScottJackson wrote:It's deep down inside the motor... most of the time. However, if it hears you bangin' around on the plenum it will come and strike. Usually it's just down chatting with the chain guides, plotting. Sometimes though... just sometimes, it has a visit with fuel injectors or the knock sensors. Those are the times when you're most likely to feel its dreaded wrath. You can't ever tell exactly where it is when you do your plenum job as it's invisible, you just have to be lucky and hope. That's the reason there's no grille on the early Q's. The engineers at nissan (who were from an evil parallel universe, as if we couldn't tell by the VH's nasty inherent attitude already) thought the VVT rod might try to exit through any percieved opening and therefore couldn't put a grille on the Q. The belt buckle was a symbol, more than anything, as a reminder that this VVT rod should be kept closed... TIGHTLY. It was later found that the upper plenum did a sufficient job of containing the invisible monster, so the grille was introduced. However, just because there may be a grille on your Q, doesn't mean there's no VVT hydrostatic rod waiting to mess you up when that plenum comes free. About the safest way to tame the beast for enough time to do a plenum job, is to get into the upper rpm's a bunch before you start wrenching. The rod will get tired from advancing the intake cam so much and will be less likely to strike. I mean, after all, this is a functional thing and not just some useless killer that was put in the Q for no reason. I don't know if it would go after a grizzly bear, but I don't think many grizzly bears would be able to navigate around all those little hoses by the throttle body or be able to pull up all those little 10mm head bolts that clamp the plenum down.
Why the wise ones do everything the first (and hopefully only) time.pito11213 wrote:Not something you wanna have to do again within a short time.
Got'em! Hook, line, and sinker!Hey Scott, whats the routine maintenance on the kanutter valve?maxnix wrote:Care to highlight that in the picture? I would like to know where this potential killer lurks.
Get an allen socket at sears or wherever. Its 6mm. You can put the socket on an extension.Kierco wrote:I am still a little vague on how to get the lower 2 bolts out of the throttle body.
I was scrambling for my safety goggles.ScottJackson wrote: that's a serious post and all true, unlike the VVT hydrostatic rod... which is just mostly true and those that don't believe have just been lucky so far.
OR GO BUY AN ALLEN SOCKET FOR $5!!!!breaksr wrote:Lower bolts on the thottle body. My favorite. Get a 6mm allen wrench (the longest one you can find) and cut off the short side. Now it looks like one long straight piece. Stick one end into a 6mm socket and stick the other end into one of those bolts on the throttle body. Get out your socket tool and turn it loose. Be careful not to break that allen wrench since it is very brittle. When you go to put it back on the plenum tighten them gradually one at a time in cross pattern (upper left first and then lower right etc.). Don't tighten any one all the way until you tighten all the others. Like tightening bolts on a cylinder head. Make sure they are good and tight since you can get gas fumes from there. Now with the money I just saved you buy new gas lines and replace the rubber gaskets between the plenum and the lower intake manifolds.
Ummm....SnapOn. Crack for the tool obsessed!Q45tech wrote:The Snap On Truck is full of expensive specialty tools:
