randybunctious »
https://forums.nicoclub.com/randybunctious-u3376.html
Sun May 09, 2004 5:40 pm
yeah you can leave the shifter in and drop it straight down all you have to do is disconnect the sensor harnes, take out bell housing bolts and starter , driveshaft, slave cylinder, all the oil, speed sensor pull the transmission spline out of the engine take pressure plate off resurface the flywheel, put the new clutch on and reverse the order. i always put new gear oil in the transmission and bleed the clutch. sometimes the rear main seal. hope this helps
