reyes1212 »
https://forums.nicoclub.com/reyes1212-u56626.html
Thu Jan 10, 2008 1:12 pm
Did you do a tutorial on when you did that to your Altima?
Well, I just finished taking the side dash pieces off and I found out the hard way the the passenger side piece has one small screw with the air vent.I ended up braking it off, but only because there was no way to fit a screw drive in that angle, but also because the piece is also firmly in place with only the clips.
There are about 8 clips on the passenger side and 4 on the driver side.
I am going to go buy the glossy paint along with wheel clear and some fine fine FINE grit to wet sand these pieces.I'm excited because don't the black dash pieces on this Versa look cool?
