Removing the shift knob!
All things Altima Coupe.
chow
Car: Altima coupe 3.5SE
I've searched around and couldn't find a thread on how to remove the knob.
I heard it was glued in and threaded in. So a simple counter clock wise rotation should loosen it up? Then I just plop in my shift knob with the correct adaptor and walah?
mcheddadi
Car: R8
yep, take all your strenth and spin it counter clock wise . then I think its 10mm adapter for it
LinkNuc
Car: 2008 Altima Coupe 3.5 SE Super Black 6MT, Loaded minus Moon Roof Deflector
yup, I used a towel and channel locks...it was also 10 degrees F but it was still a beotch to get cracked and then even a beotch to unscrew...almost like it was half-a** threaded on there in the 1st place...
Nemesi609
Car: 2008 white 3.5 se 6mt altima coupe
did it break when you were trying to take it off, and is it just the knob?
LinkNuc
No, it didn't break I meant cracked lie cracking open a beer...it was on there tight...and like I sadi even after "crascking" it it was still hard a** hell to unscrew..but the new knob went on fine
RobPaulson
Car: 2013 Subaru WRX
yeah i used a towel and a huge wrench, if you have some kind of soft clamp that is best though =p
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
Ditto on that, you kinda have to break the seal. once you get it to budge it'll unscrew pretty smooth
