Removing the rear sundeck in the 1994 Q45a (HG50)
GreenQ45a
Car: 2012 Altima 3.5 SR CVT - Dark Slate w\Black Leather Sport\Tech\Premium
2010 Pathfinder 4.0 SE Auto - Red w\Grey Cloth Towing Pkg\Tech 1
I found some write-ups that refered to butterfly clips...
The pictures are from a 1990.My 1994 has none of those.
Any walkthroughs on the sundeck removal for the 1994?I've been searching...stil nothing...
I have to replace the fuel pump now and I've heard that the easy way.
Last time in my 1993 Base Q45 I had to go back in after the dealer had forgotten to test the sending unit.So I replaced the sending unit.In the 1993 there was more room not as many computers.I didn't even remove the sundeck and the job sucked BAD...this time I want to remove the rear deck...
Walnuts
Car: 1995 Q45 with TCS 118K
Wow you and I are working with the same schedule. Two weeks ago I replaced my water pump and fuel pump on my 1994 Q45. I carefully followed steps 8 through 10 in the attached doc that Tang created. Once your in there with the document everything makes perfect sense. In the doc I made a few notes in red. It took me about 1 hr 30 min working at a slow pace to get everything complete. Couple of things. Towards the end of the doc is a picture of all the attachement points for the sundeck. Pull the postive battery cable after clearing out the fuel pressure just to be safe.
Adam
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Read my comments in Tangalora's fuel pump post.
Clips best released from inside trunk with needle nose mini pliers.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
First time you take it out will be tough as those things are really wedged in their littel holes..
