95_240 »
https://forums.nicoclub.com/95-240-u24266.html
Sun Jun 10, 2007 6:36 pm
You don't need to do what was listed above in step two. There are four bolts on the backside of the spindle that hold the hub on I think they are 14mm. You might have to rotate the axle to get a socket on the bolts. After you remove the bolts you might have to tap on the hub with a hammer to get it to come off but that's about it.
