I looked in the service manual but I would rather know from someone from experience. Hopefully this is easier than resealing the valve covers.
So how do I remove the carpet and how much work am I looking at here to do so?
Well I saw the harness for the door lock timer runs under there and meets with the main harness under the seat. I am only looking at running 10 wires max to the front of the vehicle (dashboard) so I will run them along the A, B and C pillar of the vehicle. there are many upsides to that if done correctly.BLACKonBLACK98 wrote:why would you remove the carpet to run wires? more specifically, what is at the rear of the car that you need to tap into? all power (constant, acc), grounds, locks, and lights can generally be tapped under the column or at the harness in the kick panel.
either way, removing the carpet is unnecessary. even if you have to run wires to the rear they should be run along the factory harness which can be accessed by removing the driver side kick panel, door sills, b pillar, and rear seats.
I found it rather difficult to run wires front to back (following the factory routing) without also removing the front seats. You can't just pull wires through the ducting, as they get hung up around the lower seat belt mounting point. With the front seats removed, you are more than half way toward removing the carpet. The remaining items are the rear console and front console. To get the front console out, you need to remove the rear console, radio bezel, lower left dash bezel, and lower dash cover on drivers side.BLACKonBLACK98 wrote:
