Removing the headliner - As much work as the FSM says it is?
Skibane
Car: 2000 Q45 AE 110K
Have been considering temporarily removing the headliner to install a small ham radio antenna mount above the rear window. According to the FSM, headliner removal is one b*tch of a job - Remove the front and rear seats, the instrument panel, front and rear seat belts, body side trim...plus all the crap that is fastened to the headliner itself.
Is all of this really necessary?
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
All that work for a ham radio antenna? I hope there's an easier way. I wouldn't want to go that far on my car. I think there are a couple of members here that have removed the headliner before and hopefully they'll see this thread and let you know what how they did it.
Good Luck!
Skibane
Hey, ham radio gets to be just as big an obsession as cars! I've seen hams hang some stupidly-big bug-catcher antennas on brand-new vehicles, just for the sake of a slightly stronger signal or being able to operate on a new band. Low-class bunch, we are...
I'm wondering if the part about removing the seats and IP is to provide enough room to pull the headliner entirely out of the vehicle. I only need to drop it while I slip the antenna mount through the new hole (yes, there will be drilling involved!), and then route the cable down to the ham radio.
Rex
Car: None
I partially removed the head liner from my 94, when I was contemplating swapping the grey and tan interiors between my 2 Q's. Complete removal would be a bear, but getting th erar down far enough to do what you want to do, shouldn't be too bad.
Removing the rear seats and parcel shelf are almost a necessity, to get the C-pillar trim pieces out of the way so you can get the rear of the headliner to "drop". Go slow and remove from the rear forward and you should be able to get enough clearance.
youngq45r
Car: Red 1993 Infiniti Q45- Was Granny Driven Perfect... Until I got T Boned...
Sorry too but in. What about droping it down enough to look at the sun roof motor belt? Motor spins but it just slips on the belt? How much would you have to pull out?
Rex
Car: None
youngq45r wrote:Sorry too but in. What about droping it down enough to look at the sun roof motor belt? Motor spins but it just slips on the belt? How much would you have to pull out?
I never got that far, stopped by the time I was getting to the front, once I realized how difficult dash removal was going to be.
I would think it would be difficult to remove it enough to get to the sunroof mechanism ... it would have to be nearly out by then??
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Unfortunately with the Q you have to replace the entire sunroof assy whenever the sunroof goes south...
I removed the headliner and it sucks.
DrewQ45
Car: 1990 Infiniti Q45
Why were you removing the dash?
Rex
Car: None
DrewQ45 wrote:Why were you removing the dash?
I wanted to swap the entire Taupe and black interiors between the 2 cars, as I wanted to keep the black interior, but I wanted to keep the other car ... in the end the car won out over the interior.
DrewQ45
I recently came across some old instructions for G50 dash removal... I think I got it from an Infiniti tech and the instructions are not in the FSM. It has instructions/diagrams which make it seem simple. Still, I haven't tried it so I can't comment.
dsagers
Any chance of posting those instructions?
