removing the battery tray on s14
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
i tried searching but didn't find much info, i moved my battery to the trunk and now the rusty battery tray is chilling there, it seems to be welded onto the frame or something so i abused it today as i read to do in a thread but i didn't really get it too loose..
any hints/tips for this? i took the battery's negative ground off i think there is another bolt to the right of it not sure what that hooks up to tho
TIA
MAx
Sxse240
Car: cars, computers, moneys, significant others, sometimes the stickey green.
I would pull that bolt and see what happens.
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
yea well that bolt isnt the only thing holding it in, near the tirewell its like welded on or soldered or something cause it sticks to it and wont come loose.. i was wondering how harrd you guys had to rape that part to get it off
Max
nismofan14
I removed mine. After all the the bolts are out you will have to drill out all the spot welds, about 15 of them, then pry it out of there. Its not really easy and you will bend ****.
EazyBreazy
you could just use an hand grinder to grind off the rails and make it smoth with the rest of the inner fender, or at least smoother..thats what im going to do when i get back to the states and start on my kat...
virus77
Car: 95 S14, 71 240z, 97 e320
ya the battery tray is a real PITA. After trying to take it off nicely i got pissed at it and persuaded it with a crow bar and a cutting disc, not too pretty but its off.
