180fan »
https://forums.nicoclub.com/180fan-u3602.html
Tue Oct 28, 2003 1:51 pm
The actual overhaul for the seals and bushings isn't hard, just a couple of seals but it's getting the rack off that's a total pain. There aren't too many seals or bushings, i believe one or two on the actual rack, and a couple more at the ends where the rack meets the tie rods. The hardest part will be getting it out and putting it back in once you've replaced the seals. Be sure to have plenty of grease as well, and that when you're going to put the rack back in to have some ATF lying around so you can fill up some of the atf into the rack (less work when you're pumping the power steering system). To tell you my own experience, wear gloves that protect your knuckles when trying to remove the connection to the steering column.
If you've got a leak, check the boots. The boots are usually cracked to hell on a car as old as the s13. Every s13 I've seen and worked on has cracked boots. You'll want to clean the area and regrease it before putting the new boots on. Reason for that is if the area under the boots has alot of debris like pebbles and what not, it'll damage your rack if they manage to get in a lil deeper. I had a ps fluid leak so I went a bit deeper but usually new seals and bushings aren't required as they're pretty damn beefy and mine were still fine when I did an overhaul at 140k. So I could have just gotten away with the new boots.
the power steering pump isn't bad either. Again, after doing the overhaul you'll want to have some atf lying around to prime the insides of the pump. Just follow the FSM and you should be fine.
