removing TCS.
ejXa q45
Car: 1992 Q45 infiniti sliver
so i had a problem with acceleration i my 92 q45 .i took me forever to figure it out but, i narrowed it down to a problem with my TCS .so i calibrated my TPS and STPS.. but still no luck i also checked the rear and front wheel sensors. and most of connectors for the TCS .so then i tried to put codes from the TCM unit ....i think, idk........... its the one in the trunk.but anyways i could not get the codes to flash on the unit so , i disconnected it and and it runs so much better than it did before i have no ABS but i think i will live .before i had some problems going up hills and accelerating from a stand still and a mess load of other things but now it all seemed to go away . i think the system was in safe mode but not sure. has anyone had similar problems with the TCS system or it being in safe mode. and how do i and or can i remove the TCS for good....
thanks ejxa
