Removing Spark Plug WIre... idles better
Graphfixz
Car: Black 91 240SX Hatch
what does it mean when I remove a spark plug wire and the motor seems to idle better with out it?
jkerr240
Car: 93 240 sx
Means that cylinders spark plug isnt doing its job....
Graphfixz
but the spark plugs are brand new. I also unplugged the injector and got the same results.
dannys13
Car: 1990 nissan 240sx se fastback s13
hmm, im not for sure but if it is the wire that hooks to the spark plugs cylinder thats the very first to run from the fuel rail then maybe there is something clogged in the fuel rail, but u said when u un hook the wire too.
480sx
Car: 1996 Pearl White 240sx
Means you need to do a compression check.
Graphfixz
so i took off the injector on that one cylinder and the low o-ring was pretty much torn into pieces. So this time I came short of dunking the darn injector in vaseline to keep the o-rings from tearing. Now the car idles beautifully, however, when I rev it up it smokes a lot! And has pretty bad performance when I try to go around the block.
kissmeimjwsh
Car: 1989 240sx 1992 240sx 1998 s10 lowrider
sounds like your injector is stuck wide open. im having a similiar problem but ive ruled out everything but the ecu and knock sensorcheck to see if you spark plug on that cyl is wet. also crank the engine without the plugs in it and see if gas shoots out of any of themif it does, check the wires to the injector to see if your getting power to themif you are, bad injector if your not, your probobly in the same boat as me
