maxhopper »
https://forums.nicoclub.com/maxhopper-u11180.html
Fri May 12, 2006 12:02 pm
I found some directions for the 4th gen, which should be the same as the 5th gen in this case. 1. You'll need to remove the screws/fasteners that hold the center consol to the floor enough to gain access to the area below the shifter.2. Remove the two screws in the shifter handle.3. Unplug the electrical connector for the overdrive switch leads (under the shifter mounting bracket).4. Use a small pointed tool to remove the electrical leads from the plastic connector.5. Then carefully pull the handle up to remove it.
