Ubernoober »
https://forums.nicoclub.com/ubernoober-u14357.html
Mon Aug 23, 2004 4:57 pm
Use a chunk of wood between the hammer and the bolt. The last thing you want to do is whack the rod directly with a metal hammer if you miss. A tiny ding can promote cracking. Better to use a hard platic mallet and bash the rod bolt. Even better to have the shop that is machining your rod to press out the bolt.
