DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Mon Dec 30, 2002 2:12 pm
I thought rear seat removal was required, but I seem to recall that one member said they didn't have to remove the seats. Maybe different model years or something. I recall that the mounting screws are installed top-down. If that's the case, then I'm afraid you do need to remove the rear seats and the shelf. If you've never done it, it isn't so bad. The bench is held in with 2 clips. The backrest is held in with 6 screws. The tray has 3 plastic clips that just pop out.
