removing rear plastic panels help!
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
viet510racer
Car: 08 Nissan Versa SL
i have a 08 SL that came with the stock sub, and was wondering if you guys/gals have any tips of removing those plastic panels in the trunk space without breaking the clips that holds it in?
chompsticks
Car: ???? Nissan Cube Krom
If you can get a hold or find out where the FSM (factory service manual) then it should give you instructions on how to remove it.
chompsticks
http://www.texasnissans.com/fsm/Versa/2008/
FSM for 2008 Versa, you'll need the av.pdf page 40 and ei.pdf page 51
Hope that helps.
viet510racer
thanks
Return to “Versa Technical Discussions”
