removing rear deck panel
dzznuts671
Car: 1999 Q45t
please help! how do you remove the rear deck lid??? i have removed my rear seats already..i popped off the tabs on the front of the lid..dont know what else its stuck on.. do i have to remove the side pillar panels?? are the rear vents behind the speaker grills bolted down? i have a 99 Q45t. I want to see if i can repair the rear sunshade...does anyone else have this problem..i figure its just the motor..thanks for all your help!!
joe
oh yeah does anyone know of a good leather cleaner..mind as well clean my seats real good since i got them out!! its tan leather!!
THANKS AGAIN!!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
if its anything like the 94s its just going to be snapped in. the speaker grills are one piece with the deck so you dont have to remove them.
goto http://www.nicoclub.com/FSM and look in the BF section of your year's service manual. there should be a section in the INTERIOR and it will should you exactly how its setup.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Read Tangalora's excellent post about servicng the fuel pump in IOM.
The tabs are best accessed from the trunk to avoid breaking them.
dzznuts671
Car: 1999 Q45t
hey maxnix where can i find that thread exactly...thanks again guys for all the help!!
joe
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Tangalaora wrote:About the only words I can still add to this extensive conversation is that nobody has pointed out in the NICO forums that BF-22 of the '90 FSM contains the all-important instructions for removal of the "rear parcel shelf finisher" & BF-43 of the 1990 Q45 FSM provides a diagram of the rear-seat removal process.
NOTE TO MODERATORS:
SEARCH IS BROKEN
Search on Tangalora with words Fuel Pump in body of archived posts returned "No Results"
This is not true!
zerothread?id=47728
END NOTE TO MODERATORS
BT-28 in the 1995 manual shows the rear seat removal (note the original uphostering pattern form teh earlier version).
BT-12 shows the parcel shelf removal (after front trunk trim is removed).
Here is the thread
zerothread?id=6268
ALWAYS check the Articles first for knowledge (Stuck On this Forum)
http://www.nicoclub.com/subpag...shtml
96Qowner
Car: 1996 Q45
Sorry, Brian. Matt moved all the Archived threads into Recent to let Google index them. Apparently, something got bunged up in the process. You can still find the full list of tangalora's posts and find it from there, but it's a big PIA. If it doesn't get fixed soon, I'll bother Matt about it again.
Hm, I just ran a search in Archived for the Title of that thread (Fuel Pump Replacement) and it came up. Dunno. Maybe it's only Post searches that only link to Recent. It wasn't tanglaora's thread, but she used the words "fuel pump" in her posts.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
96Qowner wrote:Sorry, Brian. Matt moved all the Archived threads into Recent to let Google index them.
Thanks. I didn't know that (posted in General Chat?) and I did not search Title as many mispellings and incorrect or ambiguous words (e.g. - "Help!") make them unrealiable.
Thanks for the update.
josegonz
Car: 1999 Q 45 Dark Green
Joe,
Did you remove the rear deck panel in your car. Any advice/hints you may want to share on this project. Thanks!!!
