John Nordling »
https://forums.nicoclub.com/john-nordling-u8964.html
Fri Apr 22, 2005 6:55 pm
Thanks for responding. I used a gear puller to loosen the wheel end of the shaft, but there just wasn't enough room to push it all of the way through. The differential end can only compress so much, and there isn't room around the rear suspension cage, linkages, and exhaust to pull that end out.
I guessed that I would have to disconnect the multiple links to pull the axel flange out far enough to free the axel shaft. I took off the front and rear upper links on the axel flange, the Hicas linkage, and the brakes (so I could get to the emergency brake cable which was limiting the travel of the flange), pried the flange down, and SUCCESS. The axel is out.
Guess what, the axel side has too much free play. Since they are over $800 new from Joe at Scottsdale, I'll check out used ones. Just my luck; only the inner side can be rebuilt! For a frame of reference, I pulled the other axel for comparision, and it seems alright at both ends.
Started it up, but the vibration is still there. I guess it must be the driveshaft, but I'm going to read the posts now to see what happens if the transmission tail shaft causes a vibration.
Hey, any idea what couses an intermittent speedometer reading? Sometimes it works, sometime it doesn't!
Thanks...............John in Seattle
