Removing purple window tint.
black g50
Car: 1994 Q45 Black/Black--235/40/18's avh3100 xplode 12" and amp 160000miles.2001 rodeo 190000miles
Rear glass,and both quarter windows have bubbly purple tint.Heard about hairdryers and elbow grease to remove.But is there some super easier way to remove?Would like to have rear darkened and sides match OE tint,but back flaking off and doesn't want to budge.
IThaJ0kaI
Car: 96 G50, 90 S13 hatch
windex and a razor blade is how I have always gotten old tint off.
yodawill2000
Car: 94 Infiniti J30
I realize its not in the heat of summer right now but this is how I did it.
http://www.kingtint.com/HOW-TO-REMOVE-TINT.html
ph34r
A little late, but the real trick is having a handheld steamer. :-) Steam the tint until it melts the glue and then pull it off. Did my entire Q in 20 minutes.
http://www.youtube.com/watch?v=L9vzJDUM5Ag
ddsmith60
Car: 2000 Q45t
I agree with ph34r. I had to remove the drive and passenger side fronnt window and the rear window tint on my Q. I used a steamer and the job was so much easier and cleaner than the razor blade method. The other concern is not damaging the rear window defroster strips. If you use a steamer you do not have to worry about damaging the strips.
