Removing Power Window Motor/Regulator (S14 Body)
TheOneGuy
Car: '95 240SX SE
I already did a search on power windows and stuff and found some good info. However, in past weekends I've attempted to take apart the window motor/regulator/glass assembly in order to replace the motor (which I think is the problem) and cannot at all figure out how to get it out. I assumed that it was probably different for an S14 than an S13 and maybe the other posts had to do with an S13. Can anyone tell me how to get all that stuff out? Do I pull it from the top? Try and wedge it out some other way? Any help would be great. Thanks.
cstang1968
i did a very thorough write up on it here:
http://www.nicoclub.com/zerothread?id=96098
TheOneGuy
Car: '95 240SX SE
much obliged
foryth
Car: Black - 95 S14... Maroon - 97 Altima SE (Sold)... Pearlywhite - 05 Murano SE (Sold)... Burgundy - 06 Titan (Sold)... White - 15 Rogue SV... Green - 02 Altima SE V6...
for some reason that link doesnt work anymore ;;
edit: however i dont need the link, managed to get the motor out by disconnecting the window attachment & sliding out through the bottom.
