book-ends »
https://forums.nicoclub.com/book-ends-u3879.html
Wed May 05, 2004 8:59 am
Okay,
After looking into the bay, I think that I have a new plan. Well, it's still the same plan, but with differences. The alternator belt is a four ribbed belt, so I would need to remove that pulley and place a three ribbed pulley of the same diamter in its place. That shouldn't be a big deal. The problem arises from what I saw in the FSM:
I didn't realize that the pulley and bolt for the alternator thread onto the rotor housing of the alternator itself. If I tried to put a spacer in-line, it would use up all of the threads on the shaft. Also, there is a chance that the belt could rub against the upper radiator hose outlet from the block. The belt angle could be enough so that isn't a problem.
Once I pull the alternator apart I can determine a method for increasing the output shaft length. Right now, the first thing that comes to mind is heading down to the machine shop and making a female/female threader adapter on the lathe. That shouldn't take more than an hour, but with finals and work, it will probably end up taking me a week or more to actually get it done!
If you're interested in this solution to the power steering problem, I'll be sure to keep you informed. A remanufactured steering rack is $350 from NAPA but I think that I (we) will still run into the problem of the hesitation felt in the steering while the pump struggles to move the fluid in the rack.
Isn't there some way to make the FD RX-7 rack mate to our cars? Surely all it would take is a custom pump bracket and decreasing the output length of the tie rods right?
