Removing Motor
pete7452
Car: 89 240 sx ka24e
ls there a easy way to remove motor on ka24de with out removing head
r3v_v3ng3
Car: 91 fastback ka-t
easier way? don't remove the headwho said you have to remove the head to remove the whole motor?
OMSIN
Car: 1993 240sx Coupe SE
I actually found something that may be of some help seeing as I'm not going to go into great detail. since your not doing a swap you don't have to do every thing just do what applys to removing the engine read the text where the black and white pics are http://www.superstreetonline.c....html
mac_daddy
Car: 92 slicktop n/a
just unclip everything, undo the mounts, drain coolant, power steering and pull it out. pretty simple. no head removal
pete7452
My motor doesnt have lifting hooks so where would i put chains or straps to protect intake manifold
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
There are bolt holes the factory used. Two M8 metric threaded holes on the back right head and two more on the left front of the head. they will do fine to lift the motor out. The motor and transmission are very light for an iron block. If you have a paranoia you can also wrap a strap up to the intake manifold. It's always smart to also use an engine leveler. This takes about 30 mins from start to finish.
Alternatively, you can do it the HARD way and take the engine out from the bottom.
