removing metal battery tray!
ayjay
geebus this thing looks like crap! i relocated my battery to the trunk and am gonna run my intercooler piping through the area where this rusted metal battery tray is... but i want to get this rusted peice of junk outta there first before cutting a hole for the piping. how do i do it? i can't see any bolts holding it in, looks like it could be welded on...
here's a niiiiiiice pic of it
93180sxredtop
Car: 93 240sx sr20det
its tach welded on and its a pain in the @$$ to get off! good luck!
just cut a hole in it and spray it black!
ayjay
dammnit!! thanks for the suggestion, but i REAALLY want to take it out... do you know where it's tach'd on? cause then i could try drillin through those areas...
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
It has baout ~15-16 tack welds that hold it in place...drill each one out, then it'll come loose.
To find them under that rust, start with a wire wheel on a drill...or a grinder.
- Brian
GrilledCheese33
Car: 2008 Nissan Xterra
1972 Yamaha R5
2017 Sea Doo Spark Trixx
i've heard of people removing it with a air hammer. Try that.
-Darren
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
i was stupid and used a crowbar.. didnt make too big of a mess tho o_O
and i have an s14 btw
ayjay
thanks for your help guys, i'm gonna take a wire wheel to it to clean it up a little and try to drill out the welds if i can find em...
240sxdriftdaily
I think this is where a plasma cutter would be pimpy.
I am going to drill a large hole and the work a sawsall around it.
1WheelWonder
Car: 1991 Nissan 240sx
I used a reciprocating saw and a big *** hammer, although it's even worse looking now.
travisn
i know this is a really old post, but i just did this on my car, first i drilled out all of the spot welds out to remove the tray. then i took a look at it and say that there were a lot of tiny holes i didnt want to weld shut, so i used a torch to cut out basically all of the flat part, but leaving about an inch all the way wound. the i used structural glue ( the kind used to bond pieces together at the factory, fusor makes it, buy it at carquest) to glue a piece in its place, i didnt want to weld, then grind all of the welds and risk distorting it. no thanks, well i bonded it when used fiberal, also found at carquest. its like bondo i guess, but its more like fiberglass so its strong. now it looks mint. just recently i used a 3.25 inch hole saw to drill my inter cooler piping out... looks so clean. i just wish i had removed my relay/fuse boxes somewhere else, next winter though
i dont know how well this pic shows it, but its all i have at the moment
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
Man that looks NICE! Wish you could do that to my battery tray. Acutally, my battery tray completely rusted through about 2 years ago, so where the battery was sitting directly on the windshield washer resevoir. I finally made a tray out of some wood when the battery started poking through the inner fender liner!! LOL GHETTO FABOULIOUS!!
