radianation »
https://forums.nicoclub.com/radianation-u80142.html
Wed Jul 14, 2010 5:53 pm
I am apparently missing something obvious, because nobody is writing exactly how to remove the lower timing cover...
I have the bolts loosened but it's stuck behind the water pump pulley and won't slide out. I don't want to damage or bend it trying to force it out. Do I need to remove the water pump pulley to get the lower timing cover off? It looks like it's literally stuck on one of the 14mm bolts on the water pump.
