removing key from ignition
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
susanb
Car: 2005 Nissan Altima
Has anyone had a problem removing the key from the ignition when you park your Altima? I have to restart the car and move the steering wheel ALL THE TIME!! Sometimes it takes two or three tries before I can get the key out of my ignition. What am I doing wrong?
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
Susanb,Welcome to NICO.
2005 Altima?
I would start with the key first, then trouble shoot the problem in the steering column.
Is the key the original key (or OEM) to the car?Is it worn or bent in certain places?
Second, make sure that the gear selector is properly in the park position.
After that, you can try to give the key a little bit of a giggle when its in the steering column, but dont yank on the key and possibly break it.
If that doesnt fix your problem, I would take it to a Nissan Dealership and make them fix the problem. That is, if the car is still under warranty (which I assume it still is).bud
garthog
Car: 2002 Nissan Altima S 2.5 (Full Stillen Exhaust, Stillen QR-Pro, Upgraded E.C.U., Stillen High-Flow in
my 02 does that all the time but all i have to do is lock the steering wheel and kinda jiggle the wheel and then the key comes right out.
cblazer
Car: 2003 Nissan Altima 2.5
my 03 Altima has the same problem. Have to move the gear selector back and forth just a little to assure selection is Park and then turn the key just a little back towards on an then all the way off and if comes right out.Pain in the butt and noticed this is common on lots of Altimas.
Return to “3rd Generation Altima Sedan (2002-2006)”
