Postby
92 hbody »
https://forums.nicoclub.com/92-hbody-u198253.htmlTue Feb 14, 2012 9:57 am
Hey guys, I am feeling a bit retarded, but I can't for the life of me get the motor out of my 92 hbody 4x4.... I've got all the bolts out of the bellhousing, and even have it separated slightly. The oil pan seems to be blocked by the front crossmember/axle, am I supposed to take the pan off, drop the transmission too, remove that front crossmember/axle? Thanks in advance!
Postby
92 hbody »
https://forums.nicoclub.com/92-hbody-u198253.htmlTue Feb 21, 2012 2:01 pm
Okay... Here's how I did it... (with help:)
I dropped the cross member out of it that sits in behind the oil pan. Then I took all of the bolts out of the oil pan, then dropped the oil pickup tube (from the wheel well) into the oil pan... from there it just slid out.
