removing ka24e from 92 4x4
92 hbody
Car: 1992 Nissan Hardbody 4x4
Hey Guys, I've got a 92 hb 4x4 that has a motor that is destroyed (the girl who had it before ran it out of water). So... I found another ka24e motor that I'd like to put in, but I'm having a nightmare time removing the engine that's in it...
Do I have to pull engine transmission together, remove the oil pan, remove the front driveline/crossmember?
Please help, my wife likes the truck, but hates the 2 ton paperweight in our driveway :confused:
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
For 4x4 its easier to pull just the motor.
Just start noting where stuff goes and take off the intake bits, harness, vacuum lines, ground wires, then remove the trans bolts and the motor mounts and spring it on out.
I'd freshen up the new motor and replace all the vacuum lines, rear main seal and what not before throwing it in.
