does this sound right? please tell me if i missed anything, most of this is off some superstreet website, some of it from speedoptions. The websites are both for s13s and i have an s14, please tell me if anything should go differently? thankyou.
disconnect batteryremove hoodunplug mafremove airbox, intakedrain engine, rad coolantremove fan shrouddisconnect rad hoses and heater hosesunplug the auxillary fan plugpull out radiatorremove shifter consolepull out shifter assyunhook the ECUpull ECU harness back through firewallun bolt EGRcut hoses, pull it out (gangster illegal style (how would one remove this item properly, or is it actually necessary to remove?))drain transmission fluidun bolt clutch slave cylinderremove downpipedisconnect speed sensor and unbolt it from transmission housingunbolt driveshaft bracketunbolt rear transmission mountunbolt engine mountspull driveshaft away fron transmissiondisconnect AC refrigerant linesdisconnect power steering lines
then use a cherry picker and sell that sucker on ebay
is this all? thanks, please give as much information as possible, i am dumb.
