Postby
ILikeMy240sx »
https://forums.nicoclub.com/ilikemy240sx-u16757.htmlMon Sep 26, 2005 9:23 am
I need to remove the dust collar that goes at the end of the KA transmission (where the drive shaft goes in) so I can put that on the SR transmission...
How do I remove this thing? I yanked on it hard but still can't remove it.
pretty sure you have to destroy it to take it off. You may get lucky and pry it out with a screw driver. Many people as a last resort will put a screw in it and yank it out with a pair of pliers.
Postby
dustyk »
https://forums.nicoclub.com/dustyk-u13031.htmlWed Sep 28, 2005 11:51 am
When I did my swap, I actually found out that you dont need to swap the SR one for the KA one. The only problem that using the SR one has is that the dust collar is a bit too long and rubs against that big rubber and bolt dampener on the driveshaft. 5 mins with a hacksaw will solve your problem
